zombiess
Picture of bike attached. Super short 37" wheel base, so I have to weigh shift a whole lot during acceleration and hard braking. Front fork does not have enough spring rate so I will be replacing it tomorrow. During riding the front shock will regularly bottom out under just slight braking which changes the geometry. Luckily it only has 2" of travel. It will be good for my future wifes ebike since she weighs under 100lbs and I'm 175.
Motor is a 9C 2806 with the phase wires upgraded to 12 AWG, holes drilled in side covers and all hall sensors upgraded to Honeywell SS41's after a crash at the Grange track caused a short and popped one of them. Even with the flaws the bike rides well, but takes some getting use to, mainly because you must weight shift to ride it. It will power wheelie at 35mph if and go WOT if you are sitting upright, not good if you aren't expecting it.
Controller is one of the famous modded ones from Lyen (can't recommend or thank him enough for all the help he's been to me). I didn't like the block time set at 1.0S so I did a little hex editing and dropped it to 0.2S which made the bike so much smoother when leaving from a stop, probably going to drop it down to 0.1S, not sure what happens if I try 0.0S. This is an 18 FET 4115 controller using the newest EB318 board. It has only 3 shunt wires installed and I noticed that they have some solder on them. The shunt has calculated out to be 1.25 Ohms after my first test ride (Lyen said 1.3 to get me in the ball park).
Battery is 124.5V hot off the charger, 30S2P LiPo 20C 6S Turnigy
Settings are 130 Phase Amps, 50 Battery Amps (but see up to 56A for a second with a brief 66A peak). Speed 1:40% 26 mph, Speed 2: 70% 42mph, Speed 3: 105% 55mph, probably just a hair faster since I did the 55mph @ 119V.
Safety equipment is a full face carbon fiber bmx helmet, bicycle gloves, wind breaker, jeans, some sort of glasses, 203mm front rotor with a Avid Juicey 5 (wow is this thing awesome) and moderately sized testicles.
When I let my friend ride it tonight he was going about 30 mph and flipped the switch from position 2 to 3 without letting off the throttle, he was greeted with an instant but controllable power wheelie and was heard exclaiming "Holy shit!" in surprise. He's 6'5 205lbs so he doesn't fit on the bike so well.
Tomorrow he is lengthening another swing arm I have for this bike by 8" and I'm installing a much nicer 100mm travel front fork. With these mods done the bicycle should be much more predictable and stable... until my new motor shows up
I have a 4 channel logging k-type thermocouple I plan to install in the controller before making some changes to it for handling more current and having better cooling. After beating around on it for the 2.5 mile ride home which was between 30-54mph with the 54mph I stuck one of the thermocouples into the phase coils of the motor to get an idea of how hot it was. I picked a spot I could go as deep as possible, but it had been about 5 mins since I got off the bike and the highest reading I got was 61C/142F. Ambient temp was 13C/55f. Controller case was 27C/81F. Phase wires, barely warm.
Bicycle scales in about 70lbs. I can't wait to do the fork and extended swing arm, this thing should be nasty. Then I need to worry about reliability of the controller, not to sure if I'm stressing it very hard or not, doesn't seem like it, at least not with our current weather.
